Leaking t-case
Old Feb 6, 2011 | 01:26 AM
aschilp's Avatar
7th Gear
Default Leaking t-case
I'm about to take my 04 Disco in for the 3rd time for a transfer case leak. What could they be missing??
1st time - said they fixed leak and when I left there was something very wrong. High whinning noise as soon as I accelartate. Said it was a loose bolt.
2nd time - fixed the whining, but next day I had a puddle under the car. I was told one of the seals tore when the TC was going back in.
3rd time? It is going back next week.......
What could be missing? I have had both my Disco's serviced at this place and always had a good luck.
Old Feb 6, 2011 | 02:01 PM
It is hard to say what they could be missing.
Are they using the correct fluid?
Old Feb 6, 2011 | 10:09 PM
aschilp's Avatar
7th Gear
This place only works on rovers so I would think they have the fluid part down.
Old Feb 7, 2011 | 07:06 AM
sloan74's Avatar
Was it just leaking from the lid or a seal? A torn seal would of been pretty obvious to whoever put a new one in, I would think at least
They charging you everytime for this?
I bet some White Shepherd would have fixed you right up before even taking it to the shop.
Old Feb 7, 2011 | 07:16 AM
So, it's time you crawl under the truck, with a flash light and see exactly where it is leaking from, if need be, take a picture of it and post it so we can help you. By the way, I don't buy the whining noise being caused by a loose bolt, that can't happen, but a t/case will whine when they forgot to put fluid back in it.
Old Feb 21, 2011 | 01:40 PM
aschilp's Avatar
7th Gear
Thanks for the help. I've gotten really frustrated with this place. After the 3rd time, it leaked a little more, but then stopped after about a day and a half. I feel like at high speeds there is a vibration that I feel under my seat and the passanger seat. I feel like they messed something up taking the case in and out and from your response above, forgetting to add fluid back in the first time. I think I'll take it to a transmission shop now to get a 2nd opinion unless anyone has other suggestions??
rally1
Feb 22, 2022 06:22 AM
hilltoppersx
Aug 26, 2010 06:47 AM
mrrepairman
Aug 29, 2009 07:19 PM
Chrisinhouston
Aug 17, 2009 11:51 AM
malmberg
Jan 4, 2009 04:32 PM
