leaky power steering pipes
Old Aug 30, 2011 | 01:24 PM
tommy's Avatar
6th Gear
Default leaky power steering pipes
hi all, just noticed today that the pipes under the radiator were leaking fluid any idea how much they are to replace and can or is it worth it too put on second hand ones,i lookes like a 3 hour job too fit them,nae luck there then..
Old Aug 30, 2011 | 09:22 PM
buick215's Avatar
If the leak(s) isn't to bad you might want to try valvoline power steering fluid with stop leak. There have been people on this forum that have tried it and have experienced good results.
Old Aug 31, 2011 | 09:30 AM
How many miles on your truck? If you at 100,000 miles plus then replaces all 3 hoses and do it right.
Some of the stop leak products work on piping and seals,not hoses. UNIVERSAL PRODUCTS MAKES THE BEST HYDRALIC STOP LEAK WHEN YOU FOLLOW THE DIRECTIONS.
Old Aug 31, 2011 | 01:52 PM
tommy's Avatar
6th Gear
theres 84000 on the clock, there well corroded so ive spoke to my local garage and the guys going to replace the pipes, its costing 200 quid so its getting done tomorow before it gets worse,thanks for the replys.
amfoto1
Jan 10, 2015 04:54 PM
FlyingZebra34
Apr 18, 2014 02:00 PM
aiden
Nov 8, 2009 08:41 PM
dmuller
Freelander
Mar 28, 2009 04:11 PM
madmax
Jul 8, 2007 05:54 PM
