LED gauge cluster etc
Old Nov 21, 2016 | 07:46 AM
Joe!'s Avatar
Default LED gauge cluster etc
Is it worth the effort to change all the gauge cluster bulbs to L.EDs? Was trying to find a kit maybe. Also want to do AC panel and clock as those aren't lit now anyways. Maybe go with blue? Is there a kit that is sold?
Old Nov 21, 2016 | 09:44 AM
JUKE179r's Avatar
TRIARII changed his dash bulbs to the red LEDs...
https://landroverforums.com/forum/di...29/#post585574
Old Nov 21, 2016 | 12:23 PM
Joe!'s Avatar
Saw that. Thank you, know anything about the clock/odometer/Climate control? I'm thinking like a white color so it matches all the other lights I have unless there's a green filter on them which would make it a Nasty color
Old Nov 21, 2016 | 03:20 PM
JUKE179r's Avatar
I've read the clock has the green film on it. I reckon (jeez I've been in Georgia too long) the climate control is the same.
*EDIT* 'ere you go for the climate control from YouTube.
It's a bit confusing because he commented 3 years ago that he used the T5 LED bulb...
There's 3 for the screen and 1 either side for the up and down heater controls and 1 for the controls at the bottom I used t9 neo wedge led's, took a lot of searching on the Internet but you'll find them, or if you want to direct solder led's onto the printed circuit board, just have a play around with it
Then a year ago he wrote he used the T9 bulb...
There's 3 for the screen and 1 either side for the up and down heater controls and 1 for the controls at the bottom I used t9 neo wedge led's, took a lot of searching on the Internet but you'll find them, or if you want to direct solder led's onto the printed circuit board, just have a play around with it cheers.
Old Nov 22, 2016 | 07:10 AM
Joe!'s Avatar
*EDIT* 'ere you go for the climate control from YouTube. YouTube- Discovery 2 climate control L.E.D. Upgrade - and instrument
Thanks!! I think I'm going to completely disassemble the parts truck cluster/clock/climate control and take all the bulbs out so I can get parts numbers and that stuff. Will update here with progress
TRIARII
Nov 22, 2016 01:17 PM
achapman
Jun 25, 2013 03:40 PM
06Range
May 8, 2013 09:01 PM
TheBelly
Nov 1, 2010 08:34 PM
underpsi
Sep 1, 2007 12:51 AM
