LED turnsignals
I see, you would need to modify the passenger compartment fusebox, since the relays are soldered onto the PCB. As another project I might add that to my project pipeline.
Then simplest solution would be using resistors to mimic the resistance of incandescent bulbs. The wasted power is negligible, since it is a turn signal.
Discorama (08-17-2020)
