LED turnsignals
Old Aug 14, 2020 | 04:47 PM
Art H's Avatar
Default LED turnsignals
I really do not want to run resisters, but I would like to run LEDs in the turnsignals. We all know that Facelift Disco have weird two place relays, does anybody have a proper way around this?
Old Aug 15, 2020 | 03:31 PM
The_OGCJR's Avatar
So you mean NOT on the fenders right? Cause you can buy those on eBay, Amazon etc
Old Aug 15, 2020 | 04:26 PM
Art H's Avatar
I mean replacing the incandescent lamps in the front and rear turnsignals with LEDs. To do so needs either an LED compatible relay or resisters. I do not want to use resisters, so that leaves trying to figure out the Face Lift Disco2's weird dual relay system
Old Aug 15, 2020 | 11:56 PM
Discorama's Avatar
You mean something like this? https://www.ebay.com/itm/264822862121
Old Aug 16, 2020 | 09:16 AM
Art H's Avatar
that would work on a normal D2. The face lift model uses two seperate relays, one for each side of the truck
Old Aug 17, 2020 | 01:09 AM
Discorama's Avatar
I see, you would need to modify the passenger compartment fusebox, since the relays are soldered onto the PCB. As another project I might add that to my project pipeline.
Then simplest solution would be using resistors to mimic the resistance of incandescent bulbs. The wasted power is negligible, since it is a turn signal.
Old Aug 17, 2020 | 03:48 AM
JUKE179r's Avatar
Soldering in a 50W/6ohm resistor in parallel of both turn signals is easy to do. No more hyperflash with LED bulbs
aemnky606
Feb 25, 2020 08:37 PM
satxpipe
Oct 20, 2017 02:07 PM
gonebaby
Jul 29, 2014 08:18 PM
TRIARII
Dec 9, 2013 06:24 PM
hilltoppersx
ROAMING WITH FRIENDS
Jan 28, 2010 01:54 PM
