Lets play "Name that Leak"
Old Mar 17, 2021 | 08:30 AM
Big Jim Swade's Avatar
I had a similar leak on mine. It stopped when I did the head gaskets. I think it was coming from the valley pan gasket.
Old Mar 17, 2021 | 09:19 AM
Micmac's Avatar
Originally Posted by Richard Gallant
@Micmac drop the plate it just an inspection plate, run a clean rag around the inside. Next you have oil all over your pan it could easily be blow back.
Clean everything up before you go to blue devil
Clean cardboard underneath
Let your engine get to temp at idle, let it idle for at least 15 minutes or so
Shut down leave it for 30 minutes or so
Now see where the oil is.
I did all of the above and let it idle for 1hr. Checked it a couple times over the course of an hour. No drips. I’m hoping tightening the valve cover fixed it for now. I looked up in the inspection hole and it seems dry up in the bell housing. Hoping it was just blow back
Magnolia18
Jun 23, 2024 06:31 PM
04disco2va
Dec 13, 2020 04:16 PM
s10lowrider1994
Aug 15, 2018 10:24 AM
golgafrinch
Jan 5, 2015 10:33 PM
