LiFePO4 Power Queen Battery 100 AH
Perhaps you already know this....but for those who don't....one of the negatives to the Renogy DC-DC chargers is that if you have both solar charging and vehicle charging it will cut the output in half on your vehicle charging. The solution is to put a cutoff switch on your solar input; switch it to OFF when you are on the road so that you get the full 50A vehicle charging.
I'm using a selector switch, because I have an off-road trailer with 500 watts of solar, so if I have items on the roof (blocking the vehicles solar panels) I can solar charge from the trailer, or both trailer and Rover, or no solar charging. Only issue is I need to manually select the solar input.
You could cut off the solar panels automatically based on alternator activity. A voltage sensing switch would do that. Could be done with a high side driver instead of a relay (more expensive but comes with built in current limit, current sensing and it doesn't wear). I also wonder if you can control the Renesys via its RS485 port somehow.
I was watching Ronny Dahl's new episode on dual battery systems this morning and saw that he has a very narrow 100aH lipo4 battery in his vehicle so I decided to do some digging and found a couple of options that might fit behind the rear cargo bins.
https://kickassproducts.com/collecti...0ah-battery-fg
https://www.amazon.com/ATEM-POWER-Sl.../dp/B09W5B9J26
