LiFePO4 Power Queen Battery 100 AH
Old May 12, 2023 | 08:51 AM
Xanthro's Avatar
Originally Posted by gecko951
Perhaps you already know this....but for those who don't....one of the negatives to the Renogy DC-DC chargers is that if you have both solar charging and vehicle charging it will cut the output in half on your vehicle charging. The solution is to put a cutoff switch on your solar input; switch it to OFF when you are on the road so that you get the full 50A vehicle charging.
Correct. If the MPPT controller is in use, even if it's 1 watt, you lose half the alternator charging, so you want either a high amp relay so you can switch it on and off remotely, or a selector switch so you can turn it off.
I'm using a selector switch, because I have an off-road trailer with 500 watts of solar, so if I have items on the roof (blocking the vehicles solar panels) I can solar charge from the trailer, or both trailer and Rover, or no solar charging. Only issue is I need to manually select the solar input.
Old May 12, 2023 | 12:06 PM
Discorama's Avatar
You could cut off the solar panels automatically based on alternator activity. A voltage sensing switch would do that. Could be done with a high side driver instead of a relay (more expensive but comes with built in current limit, current sensing and it doesn't wear). I also wonder if you can control the Renesys via its RS485 port somehow.
Old Jun 11, 2023 | 10:42 AM
gecko951's Avatar
I was watching Ronny Dahl's new episode on dual battery systems this morning and saw that he has a very narrow 100aH lipo4 battery in his vehicle so I decided to do some digging and found a couple of options that might fit behind the rear cargo bins.
https://kickassproducts.com/collecti...0ah-battery-fg
Amazon Amazon
Old Jun 11, 2023 | 04:51 PM
Xanthro's Avatar
https://www.amazon.com/ATEM-POWER-Sl.../dp/B09W5B9J26
That particular battery is great for going behind seats, as it is not deep, but it is long and tall, making it harder to place in the storage bin in the Disco Cargo area, if you have a fuse panel in the same bin.
rikkd
Jan 9, 2023 05:56 PM
escott16
May 13, 2020 11:07 PM
Rufflyer
Dec 21, 2014 09:26 PM
LR03NJ
Nov 12, 2012 03:16 PM
legendbridges
Jul 10, 2012 07:04 PM
