Lift Measurements
I have a 2" Medium Duty Terrafirma lift w/ D1 coil seats in the rear. I want to level out my ride and at the same time add a little more lift w/o removing the rear D1 spring plates. I'm looking to add spacers, but am unsure as to what size for the front and what size for the rear. 1/2" in the rear and 1" in the front??
Background on the D1 spring plates, I initially wanted the rear rake look, but after have installed the D1 plates I'm looking to level out the stance while keeping the additional height I gained from the plates (spacers in a way). If I were to remove the plates I could potentially get the stance back to the original lift height yielded by the MD Terrafirma kit and the stance would be level. But, I'm looking to gain a little more height.
I should have originally went w/ a 3" lift.![Mad](https://landroverforums.com/forum/images/smilies/MMiQGA5.png)
What are my options to get my truck to sit level and at the same time increase my current lift height w/o replacing the springs?
Here's what I'm working w/ now.
![](http://i194.photobucket.com/albums/z27/ejcoors/2012-09-26_10-54-17_459-1.png)
Hmm. Well that's odd. I recently put a 2" lift on my DII and used 2" OME springs in the front and spacers in the back (I have SLS air suspension). I measured from the center of the wheel to the wheel arch when it was done and both the front and back came out to exactly 21". And mine sits perfectly level.
Coors, sorry I did not post pics yet. Been a little busy. My front is at 21" even and rear is at almost 22 1/2". I did the TF 3" HD lift. I have ARB on the front and a Blue top optima so that has added some weight, I have a Tactical rear bumper to put on and just removed my running boards waiting for the TF sliders with tree guards. I bought a 1" space for the front hoping it will sit level after I install it as well as the other parts. I will snap a pic in the am and post it for you. It is odd that your rear sits a little lower...
The wheel arches are undoubtedly at different heights. The front is cut higher on the body to allow the front wheels to swivel in and out. Right?
My guess: you're rear numbers are little lower than some other people's because you've got a seven seater. It looks fine to me. Even rave shows that the stock numbers are .7 inches higher in the front, I'm guessing because the front wheel well is probably bigger to allow for the wheel to be turned while flexing the suspension.
