Lift problems
Old Feb 7, 2009 | 03:56 PM
raptorial's Avatar
4wd High
Default Lift problems
I just finished installing a 2" OME heavy springs lift on my 96 Disco and it came out very uneven. Prior to lift both rear and front were the same height. POst lift the back driver side is almost an inch lower than passenger rear. The front driver is lower, but I assuming that is from the sagging back. Driving and just looking at it you can see that it is very uneven.
I installed the right springs and I can not see any problems with the installation unless the back driver was upside down.
Could the spring be installed upside down or are both ends the same??
Only other ideas is a bad spring.
Can anyone help on this one??
Old Feb 7, 2009 | 04:23 PM
raptorial's Avatar
4wd High
Default RE: Lift problems
Also, the stock springs were nearly the same size as the 2" lift springs. I know this is not equivalent to lift, but it seems that the new springs should be a taller.
Any insight on this?
Frustrating after all that, a bad lift.
Old Feb 7, 2009 | 05:47 PM
rrhyne's Avatar
I haven't done it myself, but I've read that the passenger and drivers side springs are different heights. Maybe you got them mixed up?
Expedition Exchange ships theirs matched, info somewhere here:
https://www.expeditionexchange.com/ome/indexsprings.htm
Old Feb 7, 2009 | 05:58 PM
avking's Avatar
Yes, just did mine yesterday. A is drivers side and B is passenger. They are very different.
Old Feb 7, 2009 | 08:11 PM
raptorial's Avatar
4wd High
Ok thanks for the A vs B. Also, on the back they sent me a 761 and a 762 instead of 2 762s!! I should have looked before I put them on, but a little frustrating.
Thanks for the help!
Old Feb 8, 2009 | 08:29 AM
have them send you a matched set of 762's for the rear, what set of coils did they send you for the front, should be 751's?
Old Feb 8, 2009 | 01:37 PM
raptorial's Avatar
4wd High
The fronts are both 751 with A and B. It is just the rear with the problem. So, I should sent both back to get a matching pair? Great will do.
Thanks
Old Feb 8, 2009 | 02:52 PM
raptorial's Avatar
4wd High
AV and others-
I pulled off the front springs to check them and the A spring is only about 1/2 " taller than B. The stock springs i took off where about a 2 inch difference. What was the difference between A and B for you??
Do I have 2 of the same??
Thanks!!
Old Feb 8, 2009 | 03:14 PM
avking's Avatar
I did not measure the difference. Sat them next to each other and noticed the height difference. That is when I called British Pacific to find out what goes where. Nothing in the box to tell you and no directions whatsoever. These OME springs may be the best for our trucks, but the customer service is seriously lacking. How can you make two different sizes and not tell the customer what goes on each size.
Also, I have medium duty instead of heavy duty, so my measurement would not be a good comparison. I would just go A and B on the correct side, then fix the rears and see how it looks/drives. Who did you buy them from?
The rear springs don't necessarily have an up and down side. They say tighter coil goes up, but on mine they were identical top and bottom, when measured with a caliper. The front has a definite top and bottom. The side that has a flat bottom goes up. The round bottom goes down and there is a cut out to locate it in the perch properly.
Old Feb 8, 2009 | 06:00 PM
raptorial's Avatar
4wd High
Thanks for the info.
Just got the fronts in with the right A and B. Looks much better. Now all I need is the right back set.
I bought them from offroad.com in Florida.
What size tires did you put on?
Emperor_MA
Jun 15, 2011 11:21 AM
calebbo
Feb 10, 2011 04:58 PM
LRDISCO
Feb 1, 2008 12:04 PM
Mr. Krisztian
Aug 16, 2007 11:36 PM
Bigmonty
Aug 8, 2007 07:13 AM
