lift questions
Old Aug 7, 2009 | 07:16 PM
  #41
mx52star's Avatar
I 4 wheel in trails with water and mud and i go in the sand to is a 2 inch ome and 32x11.50 bfg km2 be a goos setup in the mud water and sand?
Old Aug 7, 2009 | 09:33 PM
  #42
Jupiter Rover's Avatar
Very much so. Those are great tires for the above terrain.
Old Aug 7, 2009 | 10:05 PM
  #43
malmberg's Avatar
I have the OME lift with 265/75/16 on it but I haven't found any mud to play in yet. Im not sure if you will want that wide of a tire b/c mine rub a little at a full turn. With an extra inch width it may affect your turning radius. Just something to think about.
Old Aug 7, 2009 | 11:22 PM
  #44
mx52star's Avatar
So u think 32x11.50 will rub? or should i just do 33x10.50?
Old Aug 7, 2009 | 11:59 PM
  #45
AK Rover's Avatar
I stayed with 245/75R16 so that I had a little more room in the wheel wells when my suspension articulates. I found on my last run that my rear tires rub on the rear of the wheel well when I really flex. A little trimming will solve my problem.
But this is kind of what I was saying earlier. Different terrain and location require different set up. BFG KM2 is a good all around tire for off road but that's not to say it is perfect for everything. Mud and sand don't require as much suspension travel as crawling over rocks and stumps so you can do different suspension and tire combos. You just need to talk to people and do your own experimenting until you find a set up that really works for you.
By going from a 32x11.5 to a 33x10.5 you're just trading an inch of tire width for another inch of height. The net result is going to be little to no change. If the 32 rubs the 33 most likely will also.
Emperor_MA
Jun 15, 2011 11:21 AM
calebbo
Feb 10, 2011 04:58 PM
LRDISCO
Feb 1, 2008 12:04 PM
Mr. Krisztian
Aug 16, 2007 11:36 PM
Bigmonty
Aug 8, 2007 07:13 AM
