Lift Questions..
No disrespect but I am already running 265/70/16's that's what was on the truck when I bought it. Now granted I am out here in Eastern NC so unless I ever make it to the mountains which is an 8 hour ride, I will probably never run into the trails like the ones alot of you guys run on
. The most mine will ever see is probably swamp mudd and some sand taking me duck hunting.
But since you guys have more experience with them (Land Rovers)than I do I will take your advice and before i do go crazy off-road i will get a 2 or 3 in lift.
Thanks again for all the info!
. The most mine will ever see is probably swamp mudd and some sand taking me duck hunting. But since you guys have more experience with them (Land Rovers)than I do I will take your advice and before i do go crazy off-road i will get a 2 or 3 in lift.
With the air dam removed and steering stops adjusted(and no lift), I have yet to rub on my 265/75's, let along tear anything up.
But, I also wheel mostly woods trails and mud. No real rocks here in Western NY. But I can still get things twisty once in a while.
On the other side, I am doing a lift in spring. Something mild, mostly for looks. Woulda had it by now if it wasn't for a t-case that needed replaced a month ago.
Just installed the TerraFirma 3" HD front and rear from Lucky8 and then installed 285/75r16's and its a mean looking beast! The front and rear shocks read +2 but it def. picked the truck up 3+ inches... The 33" tires do rub when steering is turned to 100% and Im really worried about the rear brake lines... I was told these tires would fit and the brake lines were long enough? I'm a LITTLE worried! =(
