lift and tire question
Old Aug 15, 2007 | 10:50 PM
mcob02's Avatar
5th Gear
Default lift and tire question
Iam a newb to land rovers and to 4 wheeling, i have a disco II and want to lift it and get bigger tires. What is the biggest lif i can get with out having to modify to drive shaft, breaklines, ect?
Also what would be the best size tire to get (this is also my daily driver)
Thanks
Mike
Old Aug 16, 2007 | 01:23 PM
tailchaser0527's Avatar
Default RE: lift and tire question
My guess for max lift with factory brake lines is about 3". Upgraded stainless brake lines arefairlycheap incomparison to the mod's you're planning,so i'dplan on that in the budget. As far asto how big u should go, just remember in almost every case, any increaseintire height and/or lift is going to take away from the on road handling and ride ofany truck.
Old Aug 16, 2007 | 08:39 PM
What are you wanting to do with your truck? Remember the bigger the tire the greater the MPG loss. In the case of a 265/75/16, you will loose close to 2 MPG in town with that up grade.
Old Aug 17, 2007 | 03:30 PM
mcob02's Avatar
5th Gear
Nothing to crazy, would 245/75/16 work well without loosing to much mpg?
dose the OME shock & spring kit(Vhttp://www.roverparts.com/Parts/9393HD2.cfm) increase the ride hight?
Old Aug 17, 2007 | 03:34 PM
You can use a 245/75/16 without a lift and not too much of a change in gas mileage.
If you decide to go for a lift, shout and I'll get you in touch with one of the best spots on line to save a few bucks.
Old Aug 21, 2007 | 12:27 PM
DiscoSam2's Avatar
I replaced my stock ones with Old Man EMU springs,gave me a about 2.5 lift in front,3 in back with no problems or new parts
Old Aug 22, 2007 | 07:28 PM
mcob02's Avatar
5th Gear
Thanks for the help
Mike that would be great if you could get me in touch with a place like that.
vibrolucky
Sep 25, 2013 10:28 AM
Discolife
Jul 14, 2012 07:14 AM
Emperor_MA
Jun 15, 2011 11:21 AM
calebbo
Feb 10, 2011 04:58 PM
Bigmonty
Aug 8, 2007 07:13 AM
