lift and tires
Old Dec 18, 2007 | 08:00 PM
discodix's Avatar
Default lift and tires
Need some recommendations for lifting an '01 disco. I was thinking about a 2" rte or ome with a265/75/16 tire andwould like it tobe astiffer ridethan stock. Just need a little help on which setup to gowith.
Old Dec 18, 2007 | 10:54 PM
discotx's Avatar
Default RE: lift and tires
I have a '99 DII, and in the past week I have gone from the stock springs and shocks and 18s, to OME HD 2" kit w/ steering stabilizer and put on 265/75/16's...
Not only is the ride stiffer, but the over all feel and control of thetruck is much better...
Old Dec 18, 2007 | 10:55 PM
okdiscoguy's Avatar
I have heard that will give you more like 3" with the sag in the original suspension. I know a lot of people go with OME lifts and are very pleased with the ride. I think ajh has the setup you are looking at, he might reply.....
Old Dec 19, 2007 | 11:31 AM
ajh's Avatar
ajh
I've currently actually got RTE in the front and spacers in the back. I'm trying to figure out what way I'm going to go for a more drastic suspension upgrade this year though.
Old Dec 19, 2007 | 11:37 AM
ORIGINAL: ajh
Does your truck actually have ACE, if so that may be a bit of a restraint.
If not, the sky is the limit.
Old Dec 19, 2007 | 11:39 AM
ORIGINAL: discodix
Need some recommendations for lifting an '01 disco. I was thinking about a 2" rte or ome with a 265/75/16 tire and would like it to be a stiffer ride than stock. Just need a little help on which setup to go with.
A couple of thoughts, both OME and RTE have 4 different spring ratings, on mine I am runing OME 751 coils in the front and the RTE 2" spacer and height adjuster in the rear with my air bags, I have an even 3' lift.
Have you checked your t/case to see if it has CDL for more agresive wheeling?
Old Dec 19, 2007 | 11:46 AM
ajh's Avatar
ajh
Nope no ace. I'm looking at a number of options up to an including going coilover with a 4-link front. I'm getting the sense though that keeping the stock-type setup is going to happen, I do like the idea of ride height adjustment on the coilover though as well as spring preload adjustment.
Also looked at my castor/pinion issue a bit more and the easiest fix looks like just replacing the rear front arm mounts with ones that are 1.1" lower which should fix both and put me right to 0 degrees out of spec. Should be easier and cheaper than doing arms too, if I was say doing a 5" lift then it would need to be a combination of the two but I can't see going that high. If I decide I need that much clearance I'll bite the bullet and get some D60's with Portaltek boxes or something similar.
Old Dec 20, 2007 | 05:35 PM
discodix's Avatar
ORIGINAL: Disco Mike
ORIGINAL: discodix
IfI use the 751 OME springs in the front and 763 in the back, that wouldbe a3 inch lift according to theexp. exchange website.WouldI need new driveshafts or anything else?Also, do you recommend a adj. front panhardbar.Oh, almost forgot, yes I checked for the cdl using a picture i found onlineand I havethe stud that sticks up from the plate on top of the transfer case, it is not just a blank block off plate. Thanks for all of the help!!
Alex_M
Nov 22, 2018 12:53 AM
jeffh
Feb 3, 2011 01:25 PM
pvenuti
Oct 13, 2010 03:48 PM
Mr. Krisztian
Aug 16, 2007 11:36 PM
James Vee
Jun 12, 2005 01:59 AM
