Limp mode
Old Dec 20, 2023 | 08:48 AM
vpedraza64@icloud.com's Avatar
3rd Gear
Default Limp mode
hello,
I just purchased a 04 Disco 2 with 126,000 miles on it, very clean no rust from Texas, I had. good deal but I am new to this vehicles
before I took it to Jiffy Lube there was no lights on the dash and the service they done is:
Flush the radiator
Engine oil change with filter
Transmission oil
Differential oil change
Bleed the brakes
My problem is that as soon as I left the station 10 miles in I had a Limp Mode , I took it to another shop and they connected a computer and they said O2 sensors, so I got all 4 and still doing it
Battery is from 12/23 so its fairly new
I cleaned the MAF sensor with MASS cleaner and still doing it
good thing my temperature is no higher than 180
the previous owner replaced the ZFS Transmission Shift Switch XYZ
I have Ultraguage that came with truck and the code that comes up a lot is P1884
Any input?
Old Dec 20, 2023 | 03:00 PM
mollusc's Avatar
First thing to note is that they probably didn't follow the correct procedure to fill the transmission. At a guess I'm going to say that the fluid level is low.
P1884 is not a detailed code. You need a Rover-aware code reader to tell you what the real problem is. There are several situations that can cause that code to pop -- many related to the transmission.
Also, I have never been able to successfully clean a MAF.
Old Dec 20, 2023 | 08:45 PM
Harvlr's Avatar
I’ve cleaned the MAF on my D2 and P38 which cleared pending codes that kept popping up.
Old Dec 22, 2023 | 08:52 AM
PickleRick's Avatar
You're code could be some 8 different things. Since you don't have access to a nanocom or other lr specific scanner try some easy common issue diagnostics
First things to check is making sure the MAF is plugged in fully.
Secondly, check charging voltage. These zf transmissions are very sensitive to low voltage issues. When your alternator decides not to work properly you're stuck in 3rd gear. Easy fix but not fun getting home to do the fix. You can do 60 but sadly even an obs f350 non turbo 7.3 will get to 60 before you.
​also check grounds. There's a ground strap cable to the engine under the alternator, right by the thermostat on the front fan side of the alternator mount bracket. There's another at the back of the driver's cylinder head.
A bad or forgotten ground can cause weird issues.
Old Dec 22, 2023 | 12:01 PM
3rd Gear
Thanks
I will star with the alternator and work my way down to the fuel cap
Old Dec 23, 2023 | 10:45 AM
mollusc's Avatar
Better idea is to start with reading the underlying codes to narrow down the problem.
Old Dec 23, 2023 | 11:27 AM
3rd Gear
Agreed
Old Nov 28, 2024 | 08:43 AM
Tacomahi5's Avatar
3rd Gear
Default Disco2
Please, anyone out there, do not go to Jiffy Lube for any of the same issues. That just opened up a “can of worms”.Oil change, maybe but find a real mechanic and hopeful you have done that already. Also learn you truck.“QUOTE=vpedraza64@icloud.com;885401]hello,
Flush the radiator
Transmission oil
Bleed the brakes
Any input?[/QUOTE]
Old Nov 28, 2024 | 08:46 AM
Tacomahi5's Avatar
3rd Gear
Use the transmission “sport option” to stay out of limp mode.
khuds308
Feb 26, 2018 03:22 PM
DiscoDrew9
Jan 7, 2018 08:52 PM
Woodyk
Aug 31, 2017 02:00 PM
halbertse
Aug 8, 2015 07:42 PM
floundering
Apr 8, 2014 07:38 PM
