Limp Mode
Hi, I have a 2003 Discovery II and after heavy rains here in PR I assume that the XYZ Connector get Wet. Where I can find a Picture from under the truck to know where exactly is that connector? I download the Rave manual but I went down the truck and I can"t find it.
Running the truck in Limp Mode can affect the Tranny??
Do you have any fault codes, if so what are the code numbers? Don't just guess, I have done many water crossing of 2 to 3 feet, covering the tranny and never had the XYZ give me any problems.
And yes, this should not be driven till you find and fix the problem cause starting up in 3rd gear is a hell of a load not needed.
Rickey_240
Apr 2, 2010 05:33 PM
xb70valkarye
Feb 2, 2010 10:13 PM
