link for building CDL linkage?
Old Oct 2, 2008 | 03:25 PM
Switzer's Avatar
Default RE: link for building CDL linkage?
I forgot about rust. Aluminum will work much better than steel considering this linkage for the T-case is going to be blasted with road grime, mud, and water.
Cheers,
Pete
Old Oct 2, 2008 | 06:47 PM
Willie 00D2's Avatar
Some Aluminum will break if you try to do a sharp bend. The aluminum work hardens when bent. Bend the aluminum with a radius rather then a sharp bend.And look for cracks in the bends when your done.
Willie
Old Oct 7, 2008 | 07:06 AM
detcord's Avatar
would it hurt anything to use a torch while making the bend? and should i quench in water or let it cool slowly?
Old Oct 7, 2008 | 02:37 PM
You can use a torch, but if you get it to hot it will melt. Personaly I would use steel for everything. Aluminum can strip out on the flats of the transfercaseat the worst time. I used 4130 for my cdl arm and mild steel for therest of it.
Willie
Old Oct 7, 2008 | 09:38 PM
detcord's Avatar
okay so i have my metal now, $15 at home depot for a stick of aluminum for brackets, and a stick of steel for handle. but i dont know what nut to get to secure the bracket to the nipple, help? haha
Old Oct 7, 2008 | 11:36 PM
Usea 8mm nylock stainless nut and a stainless washer. You might need to use a small wire brush to clean the dirt out of the CDL stud threads.
Willie
Old Oct 8, 2008 | 03:07 AM
detcord's Avatar
okay, but what thread gap etc...is there no difference in the threading on metric nuts?
Old Aug 8, 2011 | 06:05 PM
microbc's Avatar
Default CDL Handle for outside the truck
I know this is a very old thread but I was hoping that someone would have a picture and the dimensions of the outside CDL handle/bracket these guys came up with.
The original link is no longer active (there used to be a picture and dimensions) and I never saved the picture.
Any help would be appriciated!
Old Aug 9, 2011 | 06:13 PM
microbc's Avatar
I realized my request might not have been too clear.
What I am looking for is a picture with dimensions of a CDL handle that is accessible from under the drivers side door.
You pull/push it to engage/disengage the CDL.
There is a link in the 2nd posting of this thread that used to have the plans for making one but it is now a dead link.
If anyone has a copy they could post or send me I would appriciate it.
Thanks
turbodave
Mar 29, 2019 07:22 AM
C10B
Defender
Feb 18, 2013 02:42 AM
hilltoppersx
ROAMING WITH FRIENDS
Nov 25, 2011 07:20 PM
greenwade
Mar 16, 2010 05:26 PM
marcwestbmw
Sep 11, 2008 09:21 AM
