Lo-Hi-Neutral
Old Nov 29, 2012 | 12:55 AM
Aaron Sandland's Avatar
Default Lo-Hi-Neutral
Recently brought my 99 Disco 2 into a Land Rover Specialist to have the front prop shaft replaced...$900 later, now I can't move the 4wd from HI to either neutral or low.
Regardless of need, what could have happened in the repair that created this issue?
Also: $700 alone for front prop shaft, bit of a mark up huh?
Thanks kindly,
Aaron
Old Nov 29, 2012 | 06:17 AM
drowssap's Avatar
nothing they did should have effected the transfer case shifter linkage, but if it worked before I would bring it back.
If they used a LR replacement drive shaft that price is just about on the money, land rover charges right around $700 for a new drive shaft.
Old Nov 29, 2012 | 06:54 AM
Hope they went with an upgraded shaft, instead of original design. From the factory the propshaft did not have the extra grease fittings that aftermarket shafts have. So after a period of operation it will be subject to same failures as before. But, $900 is less than $900 + transmission, which is what a snapped shaft can take out before you can get to the side of the road. Pix of the trouble areas for the shaft.
Old Nov 29, 2012 | 09:03 AM
lr2001silver's Avatar
Banned
Wow my upgrade shaft is $300 shipped to your door. Sounds like you got screwed and probably got sold a factory shaft.
RoverLover
13
May 11, 2016 08:55 AM
samsly
Nov 25, 2007 08:04 AM
rab986
Nov 20, 2007 10:21 PM
97DISCOIDAHO
Apr 13, 2007 11:09 PM
RoverLover
Mar 2, 2006 05:01 PM
