Loadspace access from underneath?
Old Apr 19, 2019 | 03:53 PM
Bumble's Avatar
Default Loadspace access from underneath?
I'm looking to install a permanent inverter in one of my loadspace bins - probably the one on the passenger (RH) side. I've got a dual battery system working and would prefer to run a direct fused line off the house battery, down underneath along the chassis, and pop up in the most convenient spot near/in the side bin. Has anyone done this, or have any thoughts on the best and easiest way to get a wire popped up from underneath into the bins?
Is there already an access point somewhere from underneath ?
Old Apr 19, 2019 | 07:37 PM
Extinct's Avatar
Fuel pump cover under rear carpet
Old Apr 20, 2019 | 03:27 PM
Bumble's Avatar
Nothing along the side underneath? From what I understand the fuel pump is in the center.
Old Apr 20, 2019 | 03:51 PM
Fastercat's Avatar
There’s a rubber gromet for the tail lights you could come into. Remove the plastic access panel between the cubby and back door It has slotted vents in it. Remove the tail light on that side and follow the wires
Old Apr 20, 2019 | 07:20 PM
Extinct's Avatar
Yep, that will work too.
Old Apr 21, 2019 | 09:45 AM
Sandman614's Avatar
Wouldn't be hard to drill a hole and put a grommet in it.
Alex_M
Mar 5, 2021 08:54 PM
Frtpilot
Nov 9, 2018 04:05 PM
Rufflyer
LR4
Feb 25, 2017 11:59 AM
Charlie_V
Jun 17, 2014 10:24 PM
hh65flyer
Nov 11, 2011 10:01 PM
