Locating this coolant leak (with photos)
Old Dec 27, 2017 | 03:42 PM
09dewaed's Avatar
Default Locating this coolant leak (with photos)
The engine bay gives off the subtle scent of burning coolant. I check underneith the vehicle to find a wet spot under driver front. Not much of a leak and I don’t actually see an active drip. The source is under the drivers side radiator. I can’t see the true source but this is as far up as the wetness travels. The coolant level in the reservoir doesn’t seem to change. I’m hoping this means the leak is sloooowwww. Any obvious tips as to where I start. (Aside from straight up radiator replacement). Is there a common source in this area?
Old Dec 27, 2017 | 03:44 PM
09dewaed's Avatar
Old Dec 27, 2017 | 03:55 PM
Red5's Avatar
Check the two hose connections on the top, driver side of the rad. There's the main hose from the intake manifold and a smaller line that feeds back to the reservoir.
Old Dec 27, 2017 | 04:04 PM
Big Jim Swade's Avatar
It also could be the water pump gasket. Mine started leaking like that last August and it was the WP gasket.
Old Dec 27, 2017 | 04:21 PM
LR03NJ's Avatar
Yup, from that side could be the throttle body heater. Check the surrounding area.
Old Dec 27, 2017 | 07:48 PM
OverRover's Avatar
IF the leak is from the Radiator on the Drivers Side (providing it's not the tank or core) remove the Fan Shroud and have a look at the above 3 areas.
Old Dec 29, 2017 | 02:44 AM
number9's Avatar
And easy to check for leaks there.
Otherwise you need to use a good flashlight and inspection mirror to visually inspect for leaks from above and while beneath on your back looking up. Helps to remove the underbelly panel.
Your leak is not slow enough to ignore and just keep adding coolant.
earlyrover
Mar 27, 2017 03:41 PM
ZMonet
Jun 24, 2016 04:00 PM
jasons
Jun 4, 2010 07:49 PM
nottin
Dec 25, 2008 08:48 PM
Brad S1
Jul 7, 2006 10:26 AM
