Locked out of my Disco II - keylock pin sheared while in superlock mode
Old Mar 23, 2018 | 08:37 PM
Jeff Blake's Avatar
What's the roll pin? I don't remember getting one of those.
Old Mar 23, 2018 | 08:41 PM
abran's Avatar
It’s a new addition!
Old Mar 23, 2018 | 08:45 PM
Jeff Blake's Avatar
I want one!! Does it work with the original version? What does it improve?
Old Mar 23, 2018 | 11:02 PM
abran's Avatar
The original breaks. This one has a lifetime warranty(the buyer’s lifetime, not the part’s!)
Old Mar 24, 2018 | 11:55 PM
number9's Avatar
Nice.
Old Mar 25, 2018 | 06:05 AM
OffroadFrance's Avatar
Originally Posted by number9
Nice.
The people in the world of D2's don't seem to realise that they will all need to replace this lock pin sooner or later as it wears out and shears or rots away with rust especially if you only use the door key to open the truck.
Old Apr 16, 2018 | 04:22 PM
san988's Avatar
It was my turn to get locked outside the car. I can not tell how many time this Forum had helped. A BIG thank you to all the contributors
Old Dec 30, 2021 | 01:10 PM
chapmanmac's Avatar
3rd Gear
Talking Savannah Buzz to the Rescue!
I assume bad door is the driver door, so the exterior lock is not being operated to tell BCU to disable alarm and superlock.
Driver door key operates a switch that momentarily grounds certain wires to signal "lock" or "unlock" - if you have panel off and can find blue& slate colored wire and blue& green wire, great - if not
Pretzle time - Under driver side kick panel (left of brake pedal), there are connectors shown in attached. Connector 733 - pin 10, is a blue with slate colored wire. Poke a straight pin through the insulation. Use a small length of wire to touch that pin to ground for a moment. Should disarm. FYI - connector 744-pin 5, blue & green, that is the door switch contact to arm the system.
If you just can get to the system under the dash, may have to work from the BCU end, and get at the plugs for the BCU (other side of dash).
You can also force the doors to unlock from super lock by applying 12 volts to certain wires. Locate connector C0292 under steering wheel. Pin 15 (pink & purple) is common to all doors except driver. Pin 1 (Pink & slate) is super lock for same group of doors. Pin 8 (Pink & red) is regular lock for same group of doors . Driver door is separate.
Poke pins in the three various pink & something wires above. Apply 12 volts (+) to pink& slate, and 12 volts (-) to pink&purple. That may unlock super lock. If not, reverse polarity and try again... The BCU does this by sending a command to the relay driver package on the back of the fuse panel, which uses an array of relays to send voltage in one polarity or the reverse, to make door motor move to locked, or back out to unlock.
You may have system in such a tizzy that you will have to try the Emergency Key Access code (for your vehicle, 4 digit), and there is also a generic one of 1515.
Savannah Buzz!!! Thank you! I just shorted the system on my 02 discovery and I'm back on the road!
Old Dec 30, 2021 | 09:39 PM
nashvegas's Avatar
Note to everyone searching and finding this thread: Do yourself a huge favor. Disable Superlock. With Nanocom. Or have your shop do it. But - disable it. It will only f you in the future
Kordian
Dec 6, 2014 12:30 PM
jna97
Feb 21, 2014 09:13 AM
classiechef
Feb 8, 2014 11:55 PM
Shark59
May 4, 2013 09:33 PM
Fitzpatrick
Feb 17, 2011 09:09 PM
