Lockers recommended?
Just got my 01 disco a month ago, havn't wheeled with it yet(other than new development climbing some hills) i have the CDL installed, does anyone recommend putting a front or rear locker in or both? I'm just not sure if it is needed or not. i won't be doing anything to extreme but i do want it to be very capable! if so, which is best a detroit or an air locker. Thanks in advance.
I wouldn't get a locker just yet, save your money and get a Hi-Lift jack and a good recovery strap.
About the only thing you will need a locker for is DEEP mud or climbing Mount Everest.
Every time I have been stuck, a locker would not have helped, the Hi-Lift did the trick, a winch would have been easier and quicker.
You can buy the Jack at your local farm supply store or farm tractor dealer.
You can buy them on-line too but they are cast iron and a overweight whipping charge will be added.
I do live in the Mountains, just not Everest!lol. Thanks for the info, i've got the hi-lift, 4" strap, logging chain, shackles on the front and i just bought a hitch for the reciever at the rear, in which i put a beefy shackle. I'll save my nickles for now. i was looking at a hand powered puller (8000lbs) the other day for $70 that i might buy till i can afford a winch.
Unless you're doing rock crawling the main thing lockers will do it let you get even more stuck. Ok, that's simplistic, but there's a fair amount of truth to it. An extension of my sig line really.
Also with lockers you're talking upgrade to HD half-shafts at the same time unless you're a very experience off-roader and really know your vehicle and even then there's a good chance of breaking a stock half-shaft.
Unless you're rock crawling, or off-roading where there aren't any anchor points, I strongly suggest a winch before lockers.
Don't get a $79 8,000lb come-a-long, it'll be crap. If you want a come-a-long get a Mazdam or More Power Puller. They are quality but cost around $160.
A hi-lift can be used as a come-a-long but you can't move more than a foot or so at a time, then you have to re-rig, plus they can be extremely dangerous (read fatal), particularly in inexperienced hands. And especially when being used as a come-a-long.
