Locks won"t unlock
Old Feb 1, 2009 | 04:12 PM
jstreet's Avatar
5th Gear
Default Locks won"t unlock
It started with the drivers door and now the rear has the same problem. The doors will lock via the remote, the lock button inside or when we reach 5/10 mph, however, they will not unlock unless you use the key or pull the handle from inside. Any ideas?
Thanks in advance
Old Feb 1, 2009 | 04:35 PM
Default RE: Locks won"t unlock
You need new door lock actuators. The electic motors are bad, very common.
www.roverlandparts.com
www.atlanticbritish.com
Old Feb 1, 2009 | 04:44 PM
okdiscoguy's Avatar
or your clock springs are breaking, one by one.
If you try to unlock while holding the lock down, does it lift and fall right back down?
Old Feb 1, 2009 | 05:29 PM
jstreet's Avatar
5th Gear
No, nothing happens when I unlock, you can hear the motor, it sounds like it's lifting, but nothing.
budge96
Oct 26, 2013 04:44 PM
richierichrover
May 27, 2009 09:42 PM
NWRover750
May 24, 2008 01:08 PM
sdanderson
Apr 28, 2007 02:17 AM
tacker
Dec 19, 2006 12:15 PM
