loft springs and spacers
Old Dec 16, 2018 | 07:42 PM
yardpro's Avatar
Default lift springs and spacers
any issue using the 2” lift spacers in conjunction with the 2” lift springs?
Old Dec 16, 2018 | 08:26 PM
brake hoses, abs sensor wire length, and pinion angles are all possible issues
Old Dec 17, 2018 | 09:01 AM
yardpro's Avatar
Yes.
I realize I'll have the same issues as a 4" spring lift.
I'll clarify.
I can't see any problem using using the spacers in conjunction with the springs...am I wrong?
Old Dec 18, 2018 | 02:01 AM
The Deputy's Avatar
Default z
Yes, no problem using the two systems together. Granted, l didn't go with a full two inch spacer, cut them in half on bandsaw. So with the two inch Terra Firma lift and one inch spacer...it added a nice three inch lift. Originally, l added the spacers to factory springs...springs were just dead from old age and bottomed repeatedly on trails, so removed the springs for new TF lift. Wanted a bit more, but not four inches, so l cut my spacers in half.
Now, l will say...my sway bars have been removed front and rear...so l'm unsure what affect, if any, this would play on overall height. I'm assuming it would have no affect, but just wanted to mention it.
​​​​​​​ Brian.
Aj6543
Jun 18, 2018 05:41 PM
Draayer
Aug 29, 2011 03:47 PM
NewRoverOwner
Jun 3, 2009 08:00 PM
manieldunk
May 2, 2009 10:07 AM
Classic89
Jan 7, 2009 09:35 AM
