SAI to non SAI ecm conversion ?
Old Dec 16, 2018 | 07:45 PM
GCBurke's Avatar
Default SAI to non SAI ecm conversion ?
Has anyone done this? Reason I ask is my 2003 Disco 2 has a some point had the SAI plumbing removed so it throws the bank 1 and 2 related codes. Ild like to solve this by swapping to a non SAI ecm. Can
someone tell me what else has to be done to accomplish this?
Old Dec 17, 2018 | 09:10 PM
Extinct's Avatar
You can either flash a non-sai program in to your existing ECU, or swap in a non-sai ecu/bcu/instrument cluster. If you do the swap, after swapping the units you need to turn the key to position II for 20 mins to let the fusebox brain sync.
Old Dec 18, 2018 | 08:00 AM
GCBurke's Avatar
Thanks, Ive read the fuel pump is different....do I need to swap that too or is the existing one ok.
Fastercat
Mar 28, 2023 03:03 PM
2Guinness
Oct 3, 2018 05:52 PM
Llamasayswhat
Aug 12, 2018 09:36 AM
gatorm
Aug 11, 2017 04:04 AM
ajh
Nov 5, 2007 02:12 PM
