looking for advice
Old Mar 27, 2011 | 11:53 AM
franz's Avatar
Default looking for advice
2002 disco II, 62k mi
Looking for advice on how to flush cooling system and change plug wires.
Old Mar 27, 2011 | 03:10 PM
Go to the top of the page and start reading up on the how to section, its all in there.
Old Mar 27, 2011 | 11:58 PM
Jason_B's Avatar
Just changed plugs and wires, its not too bad you need a few things, and coolant is easy, undo big hose at the bottom of radiator and let it drain and then put new in. Plug wires, you have to take off the upper intake manifold, do you have SAI? Let me know if you need more details.
Old Mar 28, 2011 | 10:30 AM
franz's Avatar
Thanks for the information. The reason I am asking about coolant flushing is because when I drained from the bottom hose it only took about a gallon and a half to refill. Shouldn't it be more like 3 gallons? My concern is that I have been mixing differnt brands of coolant and once had to use tap water after a road side repair of blown hose. I feel like I need to get it all out and start over with a good 50/50 mix.
I probally need a mechanic on the wires. I am located about 100 miles from Atlanta GA. and 50 miles from Greenville S.C. Those are the nearest dealers. Does anyone have experience with a shop in those areas.
Thanks for all your help.
Old Mar 28, 2011 | 10:50 AM
hilltoppersx's Avatar
never go to a dealer
Old Mar 28, 2011 | 11:13 AM
sloan74's Avatar
/this
The plugs and wires are not difficult. You should be able to knock them out yourself.
nateandnikki
Jul 2, 2013 06:38 AM
chakadog
Apr 10, 2007 11:25 AM
BlazinBWF
Sep 30, 2006 09:51 PM
scottrocks
Apr 3, 2006 02:40 AM
dpakman91
Freelander
Mar 14, 2006 04:29 PM
