Looking for aftermarket Radiator
I have finished the dreaded head gasket work on my 02 discoII. After $300 in parts and labor(heads cleaned up and checked for warpage) and $100 in beer everything is running better than ever. However, I have a leaky radiator that needs attention. I want to replace it with an all aluminum piece. Has anyone had any luck installing a universal style all aluminum radiator? I have found several that have the proper inlet and oulet locations (gm and chevy styles) including one from JEGS for $179. I know that the replacement radiators that still incorporate the plastic end tanks are supposed to be adequate, but I like the idea of an all aluminum radiator. Thanks for any input.
Thanks Mike,
That is what I was thinking too. I found a few that should work nicely. I will keep everyone posted as I finish it up. Some are slightly smaller (an inch or less, here and there) but they are double core designs capable of cooling a 300hp engine. I also lined up a shop here in town that can either weld some mounts onto the radiator for me or I can weld some brackets that will secure it by cradling/clamping the radiator in place. Oddly enough, the entire process is looking cheaper than the $300 for an oem stlye replacement.
I am finishing up the install of a becool all aluminum radiator. Amazingly there is only a slight amount of modification required. The stock radiator mounts are easily tweaked to fit the new piece. It is a double core unit with 1" tubes and offers much more cooling capacity than the stock radiator. I can now remove the radiator in about five minutes without distrubing the tranny cooler. I should have it done and up and running in the next day or two. I will post pictures when I am finished and will be glad to answer any questions that anyone may have if they are contemplating a similar swap.
me 2
11-27-2012 08:09 AM
