Looking for aftermarket Radiator
Old Jul 12, 2009 | 07:51 PM
dsbducracer's Avatar
4th Gear
Default Looking for aftermarket Radiator
I have finished the dreaded head gasket work on my 02 discoII. After $300 in parts and labor(heads cleaned up and checked for warpage) and $100 in beer everything is running better than ever. However, I have a leaky radiator that needs attention. I want to replace it with an all aluminum piece. Has anyone had any luck installing a universal style all aluminum radiator? I have found several that have the proper inlet and oulet locations (gm and chevy styles) including one from JEGS for $179. I know that the replacement radiators that still incorporate the plastic end tanks are supposed to be adequate, but I like the idea of an all aluminum radiator. Thanks for any input.
Old Jul 12, 2009 | 09:03 PM
hazletbassist89's Avatar
Aside from suspension components and various off road accessories I've never seen any other aftermarket parts for rovers. I dunno, I could be wrong but I've never seen anything like that.
Oh and isn't a stock radiator all aluminum too?
Old Jul 12, 2009 | 09:12 PM
There are a number of after market radiators, verify the size and make sure it has all the mounts your has and get a year guarantee.
Old Jul 12, 2009 | 09:13 PM
4th Gear
The end tanks are plastic and are the weak point in most radiators. The all aluminum radiators have aluminum end tanks. I think I am most likely going to have to take an aftermarket universal style and mod it to work. Good thing I have a good supply of more beer at the ready!
Old Jul 12, 2009 | 09:21 PM
4th Gear
Thanks Mike,
That is what I was thinking too. I found a few that should work nicely. I will keep everyone posted as I finish it up. Some are slightly smaller (an inch or less, here and there) but they are double core designs capable of cooling a 300hp engine. I also lined up a shop here in town that can either weld some mounts onto the radiator for me or I can weld some brackets that will secure it by cradling/clamping the radiator in place. Oddly enough, the entire process is looking cheaper than the $300 for an oem stlye replacement.
Old Jul 21, 2009 | 09:12 PM
4th Gear
Default be-cool radiator going in nicely!
I am finishing up the install of a becool all aluminum radiator. Amazingly there is only a slight amount of modification required. The stock radiator mounts are easily tweaked to fit the new piece. It is a double core unit with 1" tubes and offers much more cooling capacity than the stock radiator. I can now remove the radiator in about five minutes without distrubing the tranny cooler. I should have it done and up and running in the next day or two. I will post pictures when I am finished and will be glad to answer any questions that anyone may have if they are contemplating a similar swap.
Old Jul 21, 2009 | 09:30 PM
Jupiter Rover's Avatar
Please do. I'm interested.
Kel-Tec-Innovations
Jun 16, 2014 07:06 PM
TRIARII
May 26, 2014 09:07 PM
me 2
Nov 27, 2012 08:09 AM
grandkodiak
Nov 22, 2011 08:21 PM
Snafu / Disco Fries
Nov 8, 2011 12:25 PM
