Looking for a complete procedure for 2001 D2 Head Gasket replacemnt.
I ordered the parts from Will Tillery yesterday, so thought I would get a head start. I've looked at the RAVE and it appears that I will have to skip around quite a bit to find procedures for all the various aspects of the job,..and doing a search here didnt find much.
Wondering if there is a beginning-to-end Head Gasket replacement procedure anywhere either in text or.....video? (that would be killer)
Brian in Austin
Brian in Austin
the rave is pretty good you just have to read it closley, but the very first listing on the disco2 page is a sticky covering most of the thing people have run up again. There is also a video out there that would be helpful if you have never done anything like that before. If you cant find it you could borrow mine.Even if you have done work like this there are a few good tips on it. I just did mine on a 2000 two weekend ago. you could PM me if you wish i could tell you what was easy and what I found to be a little tricky. mostly it's just turning nut and bolts and you will need at least one good torque wrench , i used a 3/8 and a 1/2 inch but i did my timing chain at the same time so it was a bit more complicated.
Brian
Brian in Austin
Brian in Austin
Am I looking at the right section? Can someone take a look at 169-176 and confirm please.
Brian
What I suggest is to start the project and when you have questions, just ask. With the amount of people on this forum who have already replaced head gaskets, I assure you that all of your questions will be answered.
Good luck!
Land Rover In Search of the Experience Baja 1000 Range Rover. Has a very nice walkthrough video (about an hour long IRRC)of an HG change. 2 thumbs up!
SkymonkeyONE
May 8, 2013 12:29 PM
cobbcj7
Dec 14, 2009 02:15 PM
