Looking to the future... Bobbed, chopped, and trimmed.
#21
Ok, further modified the photoshopped image. Added limb risers and an LED bar over the windshield. I'm also trying to decide between Cragars and Stock rims with spacers. Buying a set of 5 cragars is actually cheaper than a set of 2" wheel spacers plus a new set of lug nuts because mine have started to rust under the caps. Gimme your thoughts.
![Name: Xxst79M.jpg
Size: 119.9 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/56389d1683050939-looking-future-bobbed-chopped-trimmed-xxst79m.jpg)
![Name: 7eaUNJt.jpg
Size: 117.6 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/56390d1683050939-looking-future-bobbed-chopped-trimmed-7eaunjt.jpg)
![Name: SEAq5Zj.jpg
Size: 126.6 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/56391d1683050939-looking-future-bobbed-chopped-trimmed-seaq5zj.jpg)
![Name: Xxst79M.jpg
![Name: 7eaUNJt.jpg
![Name: SEAq5Zj.jpg
![Name: Rqu5zk5.jpg
Size: 124.3 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/56392d1683050939-looking-future-bobbed-chopped-trimmed-rqu5zk5.jpg)
#24
"overlanding" is the idea of long distance typically vehicle-sustained travel. If you have a vehicle with tires that large you are burning more fuel, giving the potential for more failures, and will have a harder time find tires locally.
As for coilovers, if one fails/breaks you'll be extremely lucky to find a suitable replacement anywhere but a specialized company. You have also just gotten rid of the nearly bullet proof coil spring for a coilover with 2 potential failure points that would stop you dead in your tracks.
#25
Ok, cool. Totally understand those reasons. Maybe coil overs aren't the best option, I'll do some more research on different springs and things. Still pretty set on the 35s, and pretty much all my driving will be in North America so gas shouldn't be too hard for me to find. Thanks!
#27
#28
Yea, I totally understand that. I'm currently running 32s on stock gears and I'm getting about 250 on a tank same as you. 35s with 4.11 gears will actually be a lower final drive, so there shouldn't be too much gas mileage decrease. Probably some decrease on highway, but should get the same mileage or even a lieeetle increase around town. I'm not worried about a little mileage decrease anyway as it is.
Gonna probably have to build a custom gas tank too. Factory isn't going to fit with the axle moved back and the a** moved forward, so my range will probably get cut down to around 185-200 miles excluding the jerry can holders I'll weld in somewhere.
#29
Ok, so a little update. I have my new welder and got to practice with it a little yesterday (finally). I'll start moving forward on prep for some of this stuff, though I wont be spending any money on it until I get my exhaust replaced because of my massive post-cat exhaust leak.
I did shoot RTE an email earlier about their castor corrected control arms, because I believe that their arms are just factory arms that have been cut, bent, and welded. I asked if I could get the rear arms also lengthened 3-4" so that I wouldn't have to cut and weld the rear arm mounts farther back.
I'm also going to call up some local driveshaft shops and get a quote on lengthened HD driveshafts. Maybe with a larger diameter, double cardon in the rear, multiple double cardon in the front, and a larger tube like those found on a full size truck. Not sure yet, we'll see soon.
#30
Ok, I just heard back from RTE about 30 minutes ago. He called and we talked for a few minutes. He said that he could do it if that's what I wanted done and that when I was ready to do it to call him back and he'd talk my ear off about it. He also told me about a Disco 1 he bobbed back when he was in CA and recommended maybe doing something like that, and if I was going to hack the body work to go ahead and weld in a cage and make her a convertible. I didn't have a ton of time to talk, so I didn't tell him that that was pretty much exactly my plan, but it's good to hear that my ideas pretty much exactly lined up with the ideas of someone experienced as himself. I think that RTE will be an invaluable resource moving forward in this.
I've yet to talk to any driveshaft shops, but that will happen soon. I'm really looking forward to this.
