Looking for a picture of where to put the seafoam in
Old Mar 20, 2008 | 02:16 PM
starcraft's Avatar
Default Looking for a picture of where to put the seafoam in
I am thinking about doing an induction cleaning on my 99 D2 today as it is pretty windy and hopefully will help with the smoke. However I am not sure which hose I am supposed to use to put the Seafoam into the engine. Does anyone have a picture of where the stuff should go. I appreciate the help.
Old Mar 20, 2008 | 02:29 PM
brooksa's Avatar
Default RE: Looking for a picture of where to put the seafoam in
These are the pics that DiscoMike sent me when I was doing the seafoam; just pull the hose/plug down and to the left of the red washer.
Old Mar 20, 2008 | 02:34 PM
Scanner's Avatar
Yep thats the one I used. Just make sure you have a pliers on hand to crimp the tube or it will suck down the whole can and kill the engine.
Mike says to try and draw out the seafoam intake to 2-4 minutes if possible. When I did it I had a helper hold the tube in the can while I worked the pliers. That way I could have him pull it out if I needed. Also helped to create bubbles in the line to see how fast things are being fed in.
Old Mar 20, 2008 | 03:58 PM
brooksa's Avatar
I clamped some mini vice grips on the hose to regulate the flow and that seemed to work good.
Old Mar 20, 2008 | 06:12 PM
BADBUZzZzZz's Avatar
I am going to do mine tomarrow! so that plug just pulls out by hand or with some pliers?
thanks guys!!
Old Mar 20, 2008 | 07:41 PM
seaosrover's Avatar
It will pull off by hand. It is just a rubber cap on a little metal tube. It is an auxilary vacuum stem. A short peice of vacuum hose will fit perfectly. Wait until you see how much smoke that stuff can make. ALOT!!!!
Old Mar 20, 2008 | 08:48 PM
brooksa's Avatar
I was expecting to have a 007 smoke screen going on but mine really wasn't that bad, but I did get some funny looks at red lights getting to the highway to blow it out.
Old Mar 20, 2008 | 09:12 PM
Philhowe's Avatar
Hey Brooksa same here I was a little dissapointed with how much smoke came out. I hope that is a good sign because we have newer Discos!!!
Old Mar 20, 2008 | 09:26 PM
brooksa's Avatar
I hope so too, and my TB was not as bad as I had thought it would be, but it does run and idle a lot better. Although it did throw the SES light that it still on, but going in for 60k service in a week or 2.
Kilgore Trout
Mar 8, 2014 10:50 PM
billymoto25
Nov 11, 2010 02:42 PM
The Capstone
May 11, 2006 12:57 AM
disco12
Off Topic
Feb 28, 2006 12:15 AM
