looking to put a lift on
Old Nov 11, 2010 | 11:35 AM
billymoto25's Avatar
4th Gear
Default looking to put a lift on
hi i have a 2002 disco. want to lift it and herd alll ya gotta do is buy shocks and springs for a 3 inch lift... is this true cause it seems to easy to me ha?
Old Nov 11, 2010 | 12:08 PM
sloppyjoe's Avatar
this is true. but with a true 3" of lift you will need to swap brake lines and re route abs lines for more slack. but its basically just a spring and shock swap. im doing mine this weekend
Old Nov 11, 2010 | 01:24 PM
agthird's Avatar
post pics..
Old Nov 11, 2010 | 02:14 PM
devildog01's Avatar
Call Justin Lucky 8 LLc.
Old Nov 11, 2010 | 02:42 PM
hilltoppersx's Avatar
Justin has a 3" OME lift, like stated before you will need to invest in some extended brake lines and re route your ABS Sensor lines. then depending on tire size you will need to re-gear and get hd shafts and corrective radius arms.
discoxd
Nov 16, 2008 07:25 PM
starcraft
Mar 20, 2008 09:26 PM
Disco2Guy
Jan 31, 2008 04:27 PM
JRdisco1
Aug 9, 2005 03:33 PM
