Looking for Recommendation for Water Pump Brand?
Old Oct 28, 2017 | 09:26 AM
KingKoopa's Avatar
Originally Posted by austinlandroverbill
Ordered an Airtex.
Final question: should I just put the gasket on "dry" or should I goop it up with some RTV?
RAVE seems to imply a dry gasket.
I've stopped using gaskets completely dry. When clearance issues are involved there's rarely a gasket anyway, or there's a spacer, so the issue is sealing. On water pumps I use a very VERY thin film of water pump specific rtv, or yamabond (or one of the identical products labeled by different manufacturers).
I spread it on the engine, then apply the gasket, then a thin film on the part. I'm talking a layer so thin that you might not see any of it squeeze out. Then I wait 24 hours after torqing before I refill. Sometimes if the new parts look particularly smooth, I will scuff the mating surface with a scotch bright pad.
Old Oct 28, 2017 | 12:35 PM
austinlandroverbill's Avatar
Thanks, ArmyRover and KingKoopa.
BTW, ArmyRover, weren't you going to Connecticut a while back to trailer back a Range Rover to Georgia? How'd that work out?
Old Oct 28, 2017 | 12:43 PM
Didn't quite work out for that Rangie and I
DadsDiscoII
Feb 28, 2015 03:43 PM
san988
Oct 9, 2013 08:02 PM
acg
Sep 7, 2013 01:58 AM
bosshogt
Aug 17, 2011 01:55 PM
