Water Pump brand All Makes(England) or Deutche Parts(German)
Old Jan 27, 2011 | 11:53 AM
bosshogt's Avatar
Default Water Pump brand All Makes(England) or Deutche Parts(German)
I'm replacing the crankshaft seal and have the viscus fan removed in my heated garage this week. With 95,000 miles on my 2003 I found a few small drips of coolant hanging off of my oil cooler lines. When I get in there closer I will see if its coming from the water pump. Hopefully it will be clearer with whitish trail of dried coolant.
Does anyone have an opinon on either of these water pumps. Which is better/same. I have heard All Makes 4x4 is decent OEM quality. The Deuthe parts one looks good too. I dont really car about the prices.
LAND ROVER WATER PUMP 1994-2004 RANGE ROVER DISCOVERY
Fitsiscovery 2003
LAND ROVER WATER PUMP ASSY DISCOVERY DEFENDER RANGE
Old Jan 27, 2011 | 11:59 AM
lipadj46's Avatar
Your leak may be from the front cover gasket also. I would try to get an OEM pump from will tillery or pt schram as they are one part that in my experience last a long time (128k miles). I have heard bad things about the proline pump not sure about the ones you mentioned though.
Old Jan 27, 2011 | 01:03 PM
dcarr1971's Avatar
My truck came with a water pump from Napa...it crapped out less than a 100 miles after it was installed by the dealer I bought the truck from.
I bought my replacement from Will, it's been good to go ever since.
Old Jan 27, 2011 | 07:16 PM
Get the German one.
Old Aug 16, 2011 | 07:52 PM
ajhenry's Avatar
3rd Gear
Hello All
Im new to the site and need some help asap!!!!
I have a 2003 Range Rover big body and badly need to replace the water pump. Can someone help me with some instructions on how to replace it... Also i found one one the web for $200, would that be about the right price for the OEM replacement.
Thanks much
desperate
Old Aug 17, 2011 | 06:38 AM
drowssap's Avatar
you would be better suited if you started a new posting rather than added onto a 6-month old post. You probably want to list it in the Range Rover section rather than the Descovery II section.
Old Aug 17, 2011 | 08:39 AM
sloan74's Avatar
aj this is the one you want,
Land Rover Water Pump Fits Discovery, Range Rover & Defender Vehicles
not 100% sure it will fit an 03 RR though, it fits:
Discovery I | '94 - '99
Discovery Series II | '99 - '04
Range Rover Classic | '95 | For Vehicles with serpentine belt
Range Rover 4.0 (P38) | '95 - '02
Range Rover 4.6 (P38) | '95 - '02
Defender 90 | '97
Old Aug 17, 2011 | 01:55 PM
jafir's Avatar
Nah, the '03 is going to have a BMW engine:
Water Pump | Land Rover Engine Parts at RoverParts.com
eagleconrado
Dec 16, 2020 01:53 PM
binvanna
Jan 4, 2017 03:50 AM
ellebarto
Sights N Sounds
Feb 22, 2015 09:02 PM
meltdowndave
Jan 7, 2010 01:38 PM
ArizonaLR3
Aug 21, 2007 09:56 AM
