looking at a rover in 2the hr need advice
Old Feb 12, 2013 | 03:08 PM
pinkytoe69's Avatar
Make sure you give a good look underneath for frame and floor rust.
Dave03S's Avatar
Don't worry about the dealer being 375 miles away, you won't want or need them. They tend to think of LR owners as walking wallets with unlimited Platinum Visa cards.
If you don't have a nearby independent LR shop, the interweb, your own tools, and the RAVE manual will get you through most any issues.
The obvious things to check are if ALL of the dash warning lights come on when you turn the key to the first position. Sometimes warning lights have been disabled or taped over on a troubled vehicle. Then I'd plug a code reader in to the OBDII port... listen to the engine at idle and at 2000 rpm, cold and warm. Listen for ticks, taps, other loud noises... take a stick or mechanics stethoscope and listen (carefully) to the heads/block. Find out what kind of coolant and oil are in it... and if the levels are appropriate in the overflow reservoir and on the dip stick... Drive it a whole lot... if it passes the above and you really love it, then go for it.
Old Feb 12, 2013 | 03:12 PM
pinkytoe69's Avatar
Originally Posted by blackhills
I wanted the height and visibility to take her exploring in the woods as well
You will definitely get this. That high, open view is my little daughters favorite part of my D1.
Old Feb 12, 2013 | 03:43 PM
blackhills's Avatar
Ok all good advice especially the key position tip I have rags a flashlight and my obd2 ready to go look. My wheel girl is 4the and the other rugrat is 17 mo. I hope it passes
Old Feb 12, 2013 | 04:44 PM
94svt50's Avatar
I would slow down, your rushing in. These cars can be a money pit so due diligence needs to be exercised. There are really a zillion on the market so dont worry about letting this one go. Spend some more time researching, you shouldnt be asking these kind of questions 2 hrs before going to look. Find an independent shop to do an inspection, as others have stated it will probably need front drive shaft and headgaskets if they have not already been done.
Old Feb 12, 2013 | 08:16 PM
blackhills's Avatar
thanks everyone for the great advice i pulled the trigger on it it looks to be in good shape there are some issues oilpan leak (small) and i will invest in some of your recomendations. i will buy a drive shaft as i can detect a small vibe in it. it needs some love and i have time. i can see i have alot to learn about these vehicals and i am glad to find a resoure like this fourm.thank you.
i haven felt this low on the auto knowledge tree since my uncle pointed to a 1974 gremlin with trees growing around it and said it ran when i parked it there 10 years ago its yours if you can get it to drive away......that was 20 years ago. to new adventures.
Old Feb 12, 2013 | 08:31 PM
Dgosh28's Avatar
Congratulations on the purchase. I hope you and your family really enjoy it. I just purchased an '01 last week. Please check the gasket at the base of the throttle body. There is a heater plate there and mine was leaking coolant. Seems that is a known issue with these trucks. I replaced the heater plate and both hoses that run from it and solved my coolant leak problem. Also check the "T" connection on the hoses that fit into the top of the fan shroud. I was told by the parts guy at the dealer here that those crack and you will lose all your coolant. Good luck to you.
Old Feb 12, 2013 | 08:51 PM
blackhills's Avatar
Default thanks
this weekend it comes all apart and all fluids will be replaced
Old Feb 13, 2013 | 06:13 AM
Dgosh28's Avatar
There is a really good sticky at the top of the page titled "Major Service" that will be very helpful to you.
Old Feb 13, 2013 | 09:00 AM
re: That high, open view is my little daughters favorite part of my D1
Many people enjoy the high view from Rovers.....
Attached Thumbnails looking at a rover in 2the hr need advice-lions_attack_safari.jpg
