Looks like a murder scene
There is oil everywhere. It looks like it is coming from the front but there is so much all over the undercarriage that I can't see where it is coming from. It might be the front crank shaft seal, but it doesn't look like it is coming from anywhere around the pulleys. It seems like it is only leaking while running, outside of the junk dripping from everything. Any ideas? I will be coating the underside with de-greaser tomorrow so hopefully I can see a little better. Any suggestions will be greatly appreciated.
Try tightening the bolt on top of the filter housing. Need a rather large wrench to do it, i had to use my biggest crescent to do it, and it was tight, but it helped slow the leak in a big way. I was surprised how much it helped. That doesn't mean your valve covers, head gasket, crank seal also aren't leaking though.
