It looks like someone cut one of the wires from the coolant area any help?
Yea I think I can hear what sounds like water under the glove box if im really close to it. But I had the thermostat and the sensor for the temperature changed almost 2 months ago. The coolant is the main thing draining right now it looks like I need to put some more in already. And I know I was overheating because the gauge did go up and when I popped the hood white smoke came out and the engine and hoses were burning hot.
You are probably hearing the rushing water sound because it's low on coolant, again. Fill it up to the factory recommend level when the engine is cold, keep your finger crossed, and monitor the coolant levels.
Do you have any white smoke exiting the tail pipe during cold starts? Or operating temps for that matter?
I'm not sure if the hoses are leaking but I did take some pictures of where it looks like its coming from. One of the pictures is from before I cleaned most of the oil and coolant off because the bottom was covered in it.
Land Rover - Imgur
Land Rover - Imgur
DiscoBenjamin
12-21-2010 05:28 AM
