It looks like someone cut one of the wires from the coolant area any help?
Old May 29, 2013 | 12:44 PM
coors's Avatar
Originally Posted by kevin7723
Yea I think I can hear what sounds like water under the glove box if im really close to it. But I had the thermostat and the sensor for the temperature changed almost 2 months ago. The coolant is the main thing draining right now it looks like I need to put some more in already. And I know I was overheating because the gauge did go up and when I popped the hood white smoke came out and the engine and hoses were burning hot.
If you plan on keeping the Rover order this right now ULTRA GAUGE. Get yourself familiar w/ the features and make sure to set the Engine Temp reading on the main screen so it's clearly visible. The factory temp gauge is absolutely worthless. SB will show you pics to back me up.
You are probably hearing the rushing water sound because it's low on coolant, again. Fill it up to the factory recommend level when the engine is cold, keep your finger crossed, and monitor the coolant levels.
Do you have any white smoke exiting the tail pipe during cold starts? Or operating temps for that matter?
Old May 29, 2013 | 02:12 PM
kevin7723's Avatar
7th Gear
I do want to keep it its been a great truck at first but recently I've been getting more problems and I don't make as much as I use too so depending on repair costs I may end up having to get rid of it and I want to keep it since it was my first vehicle.
Old May 29, 2013 | 02:56 PM
agthird's Avatar
are you sure you dont have any hoses that are leaking when the engine gets up to operating temp? Also look at the bottom of the coolant tank they are notorious for wearing out at your mileage.
Old May 30, 2013 | 08:49 AM
kevin7723's Avatar
7th Gear
I'm not sure if the hoses are leaking but I did take some pictures of where it looks like its coming from. One of the pictures is from before I cleaned most of the oil and coolant off because the bottom was covered in it.
Land Rover - Imgur
Old May 30, 2013 | 09:01 AM
drowssap's Avatar
get a pressure test and check it out from the height of some of that cooling I would think the rear of the head gasket or intake gasket, but you will never know unless you put a pressure tester on it.
2001SE7
Feb 13, 2011 01:11 PM
DiscoBenjamin
Dec 21, 2010 05:28 AM
grussell
May 24, 2009 09:00 PM
sloppyjoe
Apr 7, 2009 03:32 PM
meltdowndave
Apr 2, 2009 07:24 AM
