Losing coolant but not sure where
Old Oct 1, 2014 | 07:45 PM
TRIARII's Avatar
Originally Posted by cobbcj7
I had that exact same issue.. blown head gasket is most likely your problem.. get it checked ASAP! I did not because I was new to Rovers and ended up having to replace a blown motor...
Romove your oil filler cap and drag a finger inside it to see if you get a yellowish colored oil.. that means antifreeze is in there...
So if there is no yellowing in the engine oil then does that certainly rule out a bad headgasket?
Old Oct 1, 2014 | 09:07 PM
lordmorpheus's Avatar
No. Head gaskets can fail internally and externally. Internal failure can cause coolant to mix with the oil. I have had an external leak at the rear right corner for the past year. I check my coolant level twice a week, and it maybe goes down about 3/4" a week in my reservoir.
I have a set of heads already machined with the valves cleaned, but I am waiting for a "round tuit".
Old Oct 1, 2014 | 09:40 PM
TRIARII's Avatar
Hmm well as I posted in another thread, I to am not losing coolant. Have to top off every other day. Cant find any puddles on the ground and the engine oil cap is still dark brown. No coolant smell in the cabin and no overheating. Trying to figure this one out. Already replaced the throttle body heater plate and gasket. IF my headgaskets are not bad (cross my fingers) and with no visible coolant on the ground where else can coolant move to?
Regarding your leak, I assume then that an external headgasket leak would leave a visible trail or puddle of coolant on the ground then right?
Old Oct 1, 2014 | 11:22 PM
Actually... No.
Honestly, I don't know whether it is a head gasket leak, or manifold leak, but at 138k miles, I am going to change the head gaskets anyway. I can see coolant dye (I added dye a while ago) on the right side of the bellhousing, and a few drops of dye on my drive shaft, but no coolant ever makes it to the ground, in any kind of appreciable amount. I assume most of it burns off before it drips off the engine, as the leak is so slow.
When my water pump started leaking the other week, that definitely left a puddle on the ground. It was enough for me to notice as I was backing out of the driveway in a hurry.
Old Oct 2, 2014 | 08:58 AM
jamieb's Avatar
I checked the oil cap and filler neck this morning cold, no condensation on cap, it was dry. Ran finger inside neck and it was dark brown and chalky (not wet). Could not smell or detect coolant. May be close to time for oil change so I can inspect oil. Going to call someone who does Rover work and look for other mechanics in the Dallas area who may be able to test the engine or even do the gasket job if needed. Thanks!
Old Oct 2, 2014 | 09:14 AM
slabrat's Avatar
Can the block get damaged where it contacts the heads if you wait too long to replace them ?? I read (probably on here ) that the coolant can cut a channel in the block or head if left too long.
Might find that roundtuit sooner rather than later if this is true.
Would hate to see you have to have a new engine block due to a problem you new about.
But maybe that is mythical?
Old Oct 2, 2014 | 12:28 PM
drowssap's Avatar
no you are correct; if not repaired the steam can cut a grove in the head or block
DSCVRY
Jan 30, 2015 02:14 PM
aussiestuckintexas
Nov 2, 2014 02:04 AM
Disco_Fever
Dec 6, 2013 06:16 PM
DiscoBritney
Dec 19, 2011 06:24 PM
aublec22
Nov 25, 2010 09:29 PM
