Loss of Power '04 Disco
Old Apr 20, 2017 | 01:14 PM
hattbatt's Avatar
4wd High
Default Loss of Power '04 Disco
I have a 2004 Disco with a 4.6 bosh. I replaced my radiator yesterday. In doing so I had to also remove the oil cooler. Drove it around the neighborhood, let it idle up to temp ...no problems. Driving to work today and I noticed some slipping the transmission as I got it up to 50-60mph. Soon after I noticed the RPMs jumping on me and significantly less power. I quickly go to the nearest parking lot which was on a very slight hill ...the truck barley pulled into the spot. At this point oil was all over the engine. The junction where the oil cooler and hose meet had given way and sprayed oil everywhere. I let it cool down. Oil levels were still in ok range. I then jerry-rigged a temp clamp on the oil cooler line in an attempt to get it home. Started fine, sounded fine ...clamp seemed to hold. Put the truck in drive and had zero "go". as if I was in neutral. Tried all gears and nothing. Note there was zero transmission fluid thrown and I saw no signs of any other issue than the failed oil line next to the oil cooler.
Did my transmission coincidentally go the same time as the oil line popped?? Or is this an oil pressure issue?
Did not have any lights pop on. Because of the radiator replacement I had my ODB on and the temp never got above 204 -normal for this engine. Oil was still very clean.
Any thoughts?
Old Apr 20, 2017 | 07:35 PM
disc oh no's Avatar
You're sure the transmission fluid wasn't leaking? Sounds like it ran out of fluid. Especially if it had no trouble with slipping previously.
Old Apr 20, 2017 | 10:40 PM
Bom2oo2's Avatar
If you have only one oil cooler in front of radiator it's a trans cooler,
03-04 D2's only have that trans cooler stock from factory,( unless someone down the line added an engine oil cooler which sits on top of trans cooler,), so if you only have one, you have lost trans fluid not engine oil, that's why truck doesn't engage the trans & doesn't move,
Old Apr 21, 2017 | 02:51 AM
The Deputy's Avatar
^^^^This
Hopefully, refilling will solve your problem (once line is repaired correctly). But, if your trans oil looked more like engine oil than trans oil...it sounds like you were long overdue for a fluid change anyway.
Good luck,
Brian.
Old Apr 21, 2017 | 04:59 AM
hattbatt's Avatar
4wd High
Thanks everyone for the reply. You are all correct. This is my first Land Rover and have only had it a few months. The manual reads "oil cooler" and my uneducated head went straight to motor oil. It even looked like motor oil. So Brian, you called it -way overdue for a change.
Does anyone know where to find those hoses/lines? Im having trouble locating the specific ones for the '04 Disco with the 4.6
Thanks again.
Old Apr 21, 2017 | 09:06 AM
Bom2oo2's Avatar
It's extremely hard to find those lines brand new, I think it's been discontinued, but the chances are that line itself is not rupchured, I think you just dislocated it as swapping radiator, if so you have to push it back into place while pulling back on plastic clip that is on the line & let it lock back in place,,
But if you have damaged the rubber hose already since it's a low pressure system you can either replace the rubber hose with another piece of trans hose & few clamps & make sure it's tight & doesn't leak , or remove the whole line (from trans to cooler) & take to a hydronic hose shop & have them fit a new hose for you, & then put it back, ,
(It's very hard to connect the line fitting to cooler, be careful & try not to damage the connection)
Old Apr 21, 2017 | 11:57 AM
hattbatt's Avatar
4wd High
I appreciate the insight Bom2oo2. Yeah Im have a real hard time finding anything on that part. The hose itself is fine. Its the connection the Im having issue with. There is some sort of plastic sleeve or boot on the end of the other hose that isnt there on the trouble hose. Actually looks like it might have melted away or simply broken off.
Does anyone have a suggestion how I might correct this? The metal tabs are there ...maybe if I got small section of a larger hose to fit just over the metal junction and clamped that into place on both ends?? Since its low pressure, in my head that would work.
Old Apr 21, 2017 | 01:33 PM
mollusc's Avatar
I believe that the plastic part is there on the female side of the joint to hold a set of metal fingers in place around the male side. They're part of the mechanism that locks the hose in place. Presumably you could use something else to keep them tight, such as a zip tie, once the male part is in place and the fingers are locked onto it.
Old Apr 21, 2017 | 01:50 PM
hattbatt's Avatar
4wd High
Good info mollusc. Ill give it a look thanks.
dkak
Oct 1, 2013 12:49 AM
rickfish90
Aug 24, 2011 02:51 PM
ontheroadagain
Mar 27, 2008 08:10 PM
Amocat00
Feb 23, 2008 08:43 AM
DISCOBOY2000
May 19, 2007 04:41 AM
