Lost key
Old Jul 12, 2018 | 03:26 PM
National1tyres's Avatar
6th Gear
Default Lost key
Can i buy second hand ignition barell and key will it work thanks for ur help
Stripped ignition barrel off. It has been changed before. Due to 13mm nuts been cut down to bolt ignition barrel back on
so if this is not original barell what do I do next
HELP THANKS
Lost key
2002 discovery 2
lost key ignition barrel of. To start car need to switch ignition on discount battery reconnect then start car lot of hassle
HELP what do i need to buy to sort it thanks
No key. LOST CAR OPEN
HELP WHAT'S THE BEST OPTION
SECOND HAND BARELL AND KEY HELP PLEASE
£6 for kit
No key help 2002 discovery 2
Key and imobilser problem
Old Jul 12, 2018 | 04:08 PM
Dave03S's Avatar
You can go to any dealer and get a new key for your original lock... Take your ID and title in your name. Not expensive unless you want a fob.
Old Jul 12, 2018 | 05:14 PM
abran's Avatar
there are 2 small phillips (eyeglass size) at the rear of the barrel holding in black ignition swith connector. Undo 2 phillips and release connector. Insert flat head screwdriver and start the vehicle.
Then pick yourself up a matching ignition and door handle.
Gabb3r
Jan 18, 2019 08:52 PM
legendary
Apr 19, 2013 07:31 PM
wastedincome
Oct 20, 2012 06:02 AM
elpapisf
Apr 18, 2012 06:19 PM
ScottinNJ
Mar 7, 2007 11:07 AM
