LOTS of scale buildup...
Old Mar 10, 2014 | 09:59 AM
jamestfl's Avatar
Default LOTS of scale buildup...
I replaced the heater hoses that connect into the firewall this weekend and both the inlet and outlet pipes had TONS of scale inside and out. I wirebrushed the outsides before putting the new hoses on. The scale is just caked on the insides of those pipes. Should I be doing a doing heater matrix flush / back flush? What to use?
Old Mar 10, 2014 | 10:19 AM
drowssap's Avatar
you can try back flushing the heater core, usually has limited success. remove the heater hoses and just use a garden hose, blow the tap water out of the core after you done.
Old Mar 10, 2014 | 03:53 PM
Externet's Avatar
That same buildup is in your radiator waiting for summer to blow the head gaskets.
Check the cleanliness of all other hoses too. The engine block will have its share of buildup also.
I would say a very agressive chemical to dislodge such is to be planned in above freezing weather instead of coolant, for enough miles to do its work, and repeated treatments.
mdt9987
Mar 23, 2019 06:03 PM
cosmiccharlie
Off Topic
16
Mar 17, 2015 01:28 PM
pedro_malo
Jan 14, 2012 08:30 AM
SlcPunk74
Sep 6, 2009 10:38 AM
aircraftguy
Jul 16, 2009 12:50 PM
