LOTS of scale buildup...
I replaced the heater hoses that connect into the firewall this weekend and both the inlet and outlet pipes had TONS of scale inside and out. I wirebrushed the outsides before putting the new hoses on. The scale is just caked on the insides of those pipes. Should I be doing a doing heater matrix flush / back flush? What to use?
That same buildup is in your radiator waiting for summer to blow the head gaskets.
Check the cleanliness of all other hoses too. The engine block will have its share of buildup also.
I would say a very agressive chemical to dislodge such is to be planned in above freezing weather instead of coolant, for enough miles to do its work, and repeated treatments.
mdt9987
Mar 23, 2019 06:03 PM
cosmiccharlie
Off Topic
16
Mar 17, 2015 01:28 PM
