Loud metallic clunk every time I accelerate
I have a loud metallic clunk every time I lift my foot off the accelerator and then re-accelerate. Also have have a high frequency drive-line vibration present starting at 23 mph to 30 mph,.....then it fades until 49 mph and again at 70 mph. Both driveshafts are newly rebuilt and re-balanced and care was taken to insure that the driveshafts went back together the same way they came apart,...and back on the truck in the same position that they came out.
Wondering if anyone else has had this clunk, and if it might be related to my mystery driveline vibration.
Brian in Austin
Brian in Austin
Brian in Austin
Brian in Austin
Gearbox and Torque Converter Problem - Land Rover Forums : Land Rover and Range Rover Forum
I rebuilt my driveshafts using the preferred Neapco joints and Centering ball, then had them both re-balanced as I had original joints still and a driveline vibration (Driveshaft rebuild did NOT cure this) I plan on getting underneath the truck soon while a friend moves the shift lever from D to R and see if I can spot the clunk. Wondering if I have worn splines on one of my shafts.
I noticed that when I pulled the rear shaft, that the Emergency brake drum fasteners were all a bit loose, and that when I put the drum back on,......it was NOT a Snug/ tight fit over the fastening studs,....wondering if the holes in the drum might be wallered out from the fasteners not having been properly tightened by someone.
I also noticed yesterday, when I lightly pull up on the E-Brake lever while moving, that there is a LOT of vibration coming up from the eBrake drum,.....which seems to confirm my thoughts about the ebrake drum holes being enlarged and allowing the ebrake drum to be off center causing my driveline vibration perhaps.
any thoughts?
Brian
Change the transfer case fluid or at least top it off. I had the exact same "clunk" when taking my foot off or putting foot back on. My tcase was a quart or two low. Use 85w140 or follow this thread:
https://landroverforums.com/forum/di...ictures-27159/
Can't help with your vibration. Is the rotoflex that connects the rear shaft to the rear diff worn or cracking?
I would look at the roto flex as mentioned may not hurt to just replace it as you do not know how old it is. Also as mentioned the motor and transmission mounts, see if you can tighten them up. I had a weird vibration awhile ago, my mechanic and I loosened up all the mounts pushed the whole engine/tranny assembly all the way to the right then to the left make measurements and then centered the assembly. tightened everything back up and the vibration went away.
Brian in Austin
Brian in Austin
My rig suffers the exact same symptoms at about the same speeds. Looks like I have a lot of things to look into.
