Loud Ticking and Oil Light on
Old Jun 10, 2008 | 05:16 PM
paris1099's Avatar
Default RE: Loud Ticking and Oil Light on
To be honest, im not sure now. I will look for my paper work for the milage. I think it was in the mid 40's... I am trying to think based on oil changes...lol
I will get the paper work and tell you
Old Jun 10, 2008 | 05:33 PM
DiscOK-To answer your question, on LR's the oil pump is part of the front cover. The front cover also houses the timing gear set.
The defect is with the engine block, the front cover attaches to the engine block and because of the defect with the engine it wears out the front cover which in turn wears out the oil pump. If you replace the oil pump and front cover in 57k you will be in this same boat that you are now.
When the pump fails it starves the engine of oil and everything runs dry and the engine grinds itself apart.
lrjon
Nov 23, 2019 06:00 AM
p4nth4
Dec 14, 2011 08:52 AM
sloan74
May 12, 2011 10:11 PM
2003DICSO
Aug 7, 2009 06:13 PM
rovergirl79
Aug 4, 2005 02:19 PM
