Loud warm up noise
Old Feb 19, 2017 | 08:00 AM
  #61
OffroadFrance's Avatar
Engine noise and whooshing. When you start up from cold the viscous fan will be fully engaged so you can hear a whooshing noise. As the truck warms up the noise decreases quite a lot as the ram effect of moving at normal speeds takes over from the viscous effect.
The A/C fan shouldn't, I believe, wel according to RAVE, activate until the temperature ambient is 28C or the sensor stat demands the A/C condenser to be cooled if already moving or idling. If the A/C fan comes on immediately when starting from cold and the ambient temperature is below 28C then the sensor is likely to be defective or blocked.
EstorilM
Aug 6, 2014 07:58 AM
DiscoDad
Nov 17, 2010 08:11 AM
chakadog
May 23, 2010 09:30 AM
Darover
Aug 28, 2007 03:01 PM
linfieldbrah
Apr 11, 2005 03:39 AM
