Low Voltage to driver's side fuse box? 03 Disco
Old Aug 18, 2009 | 11:05 AM
kae's Avatar
kae
Default Low Voltage to driver's side fuse box? 03 Disco
I had AAA test my alternator and it appears to be outputting fine. However, when turning on my headlights they take 10 seconds or so to actually go on in low mode (the high beams go on immediately). When they do go on, the instrument cluster lights noticably dim as if the low beams are drawing power away from them. Is there some connection that gets dirty between the engine compartment fuse box and the driver's side fusebox that could cause these symptoms? Is there a better way to test the alternator other than the way the AAA guys do it from their truck?
Livingintheskies
Apr 9, 2018 11:17 PM
Dave Bristow
Feb 14, 2015 01:28 AM
rhyslegge
Apr 17, 2011 07:25 AM
Luv2Run
Aug 16, 2005 01:38 PM
