Fault Codes Please Help
Old Aug 4, 2009 | 09:57 PM
Gavster's Avatar
Default Fault Codes Please Help
Hello all, my car had been running awesome since the induction/ throttle body cleaning was done in late June. The car has new plugs and wires but was still having misfires until the cleaning. They than went away for about a month but have come back. I know the codes for the misfires but I have also gotten several new codes that I do not recognize, PO182, PO765, and P2510. Thanks for any info/advice
Old Aug 5, 2009 | 09:03 AM
183 is a Fuel Temp sensor A circuit Low Imput
765 is a Shift Solenoid D malfunction
I don't have a clue on the 2510.
What are the other fault codes you are getting?
Old Aug 5, 2009 | 09:32 AM
hilltoppersx's Avatar
2510 is ECM / PCM Power Relay Sense Circuit Range/Performance
Old Aug 18, 2009 | 01:36 PM
jallert's Avatar
Default fault code list?
is there a fault code library out there you are getting all these from? Please direct me to a sight that I could download them. Thanks
Skyelr3
May 3, 2021 08:16 PM
06Range
May 8, 2013 09:01 PM
ty8ight
Nov 9, 2012 08:45 AM
