Lower Cowling and radiator fitment?
Old Sep 8, 2015 | 05:13 PM
jdwilks's Avatar
Default Lower Cowling and radiator fitment?
So to make sure I don't install my radiator improperly trying to clear a few things up. At the Rave I am looking at Repair 26-2-17 (page 432) about removing radiator and the last two steps (steps 23 -24). So I am missing the the parts from those two steps which are the retaining clips and sealing strip. I have the retaining clips ordered and on their way to me. I just ordered the sealing strip as well hoping its in stock and ships OK. My question is I see no mention of the lower fan shroud in the Rave. Guess I am confused how the lower portion of the shroud stays in place. Previous one was zip tied to bottom of radiator and I just had my second clutch fan come apart and not sure this is the cause but wanting to rule that out as happening again. I have piece of the lower fan shroud but I having trouble envisioning how its secured trying to piece it together outside the car. Any chance of some real pics
Old Sep 8, 2015 | 06:46 PM
Charlie_V's Avatar
The lower shroud just screws to the upper shroud. One on each side where the two joint. Or, anyway, that's how mine goes on.
Old Sep 8, 2015 | 10:23 PM
abran's Avatar
There are 2 clips that attach to the bottom of the radiator that the lower shroud wedges into.
If you look at the bottom of the rad at the 2 outside positions there are 2 slots on the lip(front and back) this is where the clips, clip into the radiator.
Old Jan 14, 2017 | 12:51 PM
Jeff Blake's Avatar
Does the sealing strip fit onto the front or rear lip of the radiator?
There doesn't seem to be anything to hold the strip on, it just falls off... is it supposed to be glued or something?
Old Jan 14, 2017 | 01:25 PM
bmeier's Avatar
I ran into the small problem myself dealing with those clips and the seal. I ended up leaving the seal out but it bugs me,, I didn't want it flying off down the road.
Old Jan 14, 2017 | 08:46 PM
Bom2oo2's Avatar
I replaced original radiator 2-3 months ago with a new one twice,!! First one I put in had a bad brass fitting for secondary air that was spinning,! (It was a Nissens, so they gave me a replacement under warranty),, and I still don't remember rubber seal front or back %100, But I want to say it was on back & rubber flap section going toward front of car,,,
But it wasn't staying on either one of replacement radiators the way it stayed on original, so I put some silicone in seal's groove & pushed it into radiators aluminum lip & then put plastic clips on, & it was very solidly in place after that.
aguison
May 24, 2015 05:03 PM
Rover Newbie
Oct 7, 2013 12:53 PM
batiscan
Jul 4, 2013 05:02 AM
russburcham
Sep 19, 2012 07:07 PM
Apilky
Aug 5, 2008 05:47 PM
