Lower Engine Plastic Cover
It's sort of a pain for repairs, but I'd rather protect my engine and hises than save 15 minutes for repairs I rarely make.
I painted Ted the inside of it with Blue Engine paint so I can easily see dropped screws/bolts and any fluids collecting.
I'de like to buy the round oil filter door for my 04, as it was gone when I bought the truck.
Personally, I like the splash guard. Hot aluminum doesn't like cold water from puddles and mud holes. It also increases gas mileage, probably at least 1/10 mpg, lol.
It comes out so easy too. 4 screws, jack up frame, turn it sideways and pull it back and down.
I'm suprised that some people don't like them.
Frame or front cross member.
Where ever that lifts the frame, just to the point that the front suspension is completely extended. Front tire, or tires about to come off the ground.
You can get the oil pan off this way too.
I jack it up on the passenger side (U.S model).
That way, there's plenty of room to get the splash guard out. As said above, pull the guard back, and turn the back side of it towards the driver side. It'll turn about completely sideways, then you can pull it down and out to the left. It's really simple.
The oil pan comes off easily this way too. Only you must remove the front driveshaft, and pick-up tube (2 visible bolts with easy wrench access), then spin oil pan 180 degrees to where the back of the pan faces the front.
Pull it back and down to the left also.
I know you didn't ask about the oil pan, but just thought I'de add the info for anyone looking.
I was able to slip mine out the front by simply removing the steering stabilizer. It stays removed and it the areas it supposedly keeps clean get dirty there's better access for cleaning.
The underbelly panel prevents the early warning system(small leaks/seeps) from reaching the ground and being easily noticed while down below doing routine mx. It would be a PIA to remove for each inspection IMO and other repairs.
Likely originally installed to increase mpg by the previously mentioned 0.10 mpg and to reduce the number of reported leaks during the warranty period. To each his own.
